dyno test - Printable Version
+--- Forum: Techboard Archives 2006 (https://turboford.org/forum-techboard-archives-2006)
+--- Thread: dyno test (/thread-dyno-test)
dyno test - a-turbo - 06-24-2005
RE: dyno test - Tyler A. - 06-24-2005
Maybe do a search on how to adjust the vam. Also set the tps, that might cause a lean problem, but i'm not sure.
RE: dyno test - Dr_EluSivE - 06-24-2005
you have a model A with a 2.3T??? This i have got to see. Pics!!!!
Dr.
RE: dyno test - Turbo Raccoon - 06-24-2005
i want to see that also.
RE: dyno test - Dolphin1 - 06-25-2005
what was considered to be lean,for as rich as these engines run it would help to know this.
150 whp isnt too bad,sounds a little low.might need a little tuning.
RE: dyno test - 67baja - 06-25-2005
What was your fp at idle with the vacuum line off the reg? Should be 39# I believe.
