Vaccum pump install help -
Big R - 06-26-2005
Because of my lopy cam, I only have 10lbs of vaccum at idle, so I am going to install a vaccum pump for my brakes. Is there anyone who has done this and can provide me with install help. Thanks
RE: Vaccum pump install help -
Turbopit - 06-26-2005
I would think a reservoir would be enough. :dunno:
Big R - 06-26-2005
Pit, explain this reservior. I have very low vaccum and he way I drive I need goooood brakes. Please explain.
Many cars have some kind of "tank" that is just connected to your vac tree. Most Fords I have ever had, had one that was a sphere. Xr's have one that I think is more to help out hte HVAC systems vac opperated doors.
Are you actually having a problem with the brakes? I forget what you drive, you may just need a check valve in the line to the brake booster if your car was originally naturally asperated.
Big R - 06-26-2005
I have an 86 TC Turbo Coupe.
