Surge at idle. - Printable Version
+--- Forum: Techboard Archives 2002 (https://turboford.org/forum-techboard-archives-2002)
+--- Thread: Surge at idle. (/thread-surge-at-idle)
Surge at idle. - Codeman - 01-25-2002
My '86 Turbo Coupe surges at idle, goes anywhere from 800rpm to 1200 rpm. What do I need to look for/ adjust? It does it only when warm.
RE: Surge at idle. - B00stedBird - 01-25-2002
sounds like an IAC valve.
RE: Surge at idle. - Codeman - 01-25-2002
Tell me more, what is this valve?
RE: Surge at idle. - svobud - 01-25-2002
Idle Air Control valve - usually cleaning it will solve the problem ....or you may need to re adjust/replace your TPS (throttle position sensor)
RE: Surge at idle. - Evilgt - 01-25-2002
nine times out of ten on the 5.0 car its the IAC. clean it out like mentioned before with some carb cleaner. this has fixed every five litre car i've owned... pretty sure the IAC works and doese the exact same thing both 2.3 and 5.0 cars......
RE: Surge at idle. - Wolf2600 - 01-25-2002
Also check and make sure your orange O2 sensor ground wire is getting a good connection to the bolt on the turbo's inlet airhorn.
Patrick
http://wolf2600.streetracing.org
86 Mustang SVO 125k miles
-Ric Gillis Boost Valve
-K&N Cone on VAM
-Early style SVO headlight conversion
-Borla Turbo Mufflers
RE: Surge at idle. - GT350R - 01-25-2002
Could also be the TPS. Check out the article on NATO on how to clean teh IAC and set the TPS.
www.turbotbird.com
Thank you guys I will check the IAC and TPS tommorrow. The ground is good on my O2 sensor.
