Oil return thread? - Printable Version
+--- Forum: Techboard Archives 2004 (https://turboford.org/forum-techboard-archives-2004)
+--- Thread: Oil return thread? (/thread-oil-return-thread--71953)
Oil return thread? - BoostedZX2 - 12-29-2004
I need to know what size the thread on the end of the IHI oil return is. The actual line not the spacer that goes into the block. Thanks
RE: Oil return thread? - DrPhang - 12-29-2004
1/2 npt i believe
RE: Oil return thread? - BoostedZX2 - 12-30-2004
Well I know the one for the block is 1/2" and I just compared the block spacer to the line and they were close but the threads on the line are smaller
RE: Oil return thread? - xrattiracer - 12-30-2004
i believe the garretts use 1/2 pipe thread. the ihi might be one size smaller, 3/8 pipe thread. just guessing though, as i havent seen one of those. if you have any pipe fittings around, try screwing a few of them into it to see if any fit. failing that, take it to home depot or similar and do the same thing Smile
RE: Oil return thread? - BoostedZX2 - 12-31-2004
I went to the hardware store today and they couldn't figure out what size it is. Does anybody know for sure what size it is?
RE: Oil return thread? - BoostedZX2 - 01-02-2005
ttt
