1986 TC Project - Printable Version
+--- Forum: Member Projects (https://turboford.org/forum-member-projects)
+--- Thread: 1986 TC Project (/thread-1986-tc-project)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
1986 TC Project - tcoupeturbo - 01-22-2015
I am in the process or re-building my 1986 Thunderbird. It's purchased the car back in 1989. It was my first car and I intend to restore it, this time with my dad & son.
About a year ago, we pulled the motor to start a rebuild. When the motor was out, we found the shock towers were rusted at the base. I guess the NY winters have taken a toll.
Passanger side inner frame rail;
[Image: ff76efac-264a-41ab-a916-fb95ac63d71b_zpsfb845ec4.jpg]
I cut out the rotted section and welded in a new piece.
[Image: IMG_2016_zps29c72e0b.jpg]
Installed some steel tubes to replace the rotted inner plate steel.
[Image: IMG_2019_zps2fb7f553.jpg]
I would up having to do both sides;
Passanger Side;
[Image: DSCN0271_zps3ff793fc.jpg]
Driver Side;
[Image: DSCN0272_zpsb3c390b0.jpg]
I applied some POR-15 to hopefully prevent this from happening again.
[Image: DSCN0281_zpscf9a1580.jpg]
[Image: DSCN0284_zps745b897c.jpg]
I ordered some new SN95 length control arms from Griggs Racing to replace the old worn out arms. They should arrive early next week.
RE: 1986 TC Project - tcoupeturbo - 01-23-2015
Painted the inner fenders with 3M Undercoating. Looks like It will need another coat. I may have to wait till spring;
[Image: DSCN0317_zpsdf6758db.jpg~original]
[Image: DSCN0316_zps56e511b2.jpg~original]
[Image: DSCN0315_zpsc2edf1a0.jpg~original]
[Image: DSCN0320_zpsee354587.jpg~original]
[Image: DSCN0319_zps2f85b914.jpg~original]
RE: 1986 TC Project - tcoupeturbo - 01-24-2015
I was digging up some old photos of the build. I started collecting parts for the build in March of last year. The short block will be as follows;
.020 over bore
Stock crankshaft .010 under on mains & rods
Federal Mogul coated bearings
CP pistons - Esslinger D-port chamber
Crower 5.2 rods (re-used from current engine)
Melling M86E oil pump
Esslinger Billet intermediate shaft
MSD Billet distributer with bronze gear
Kevko road racing oil pan
[Image: P3090567_zps9cf638a7.jpg]
[Image: P3090570_zpse7a6c7e3.jpg]
[Image: P9140582_zpsfbcadac0.jpg]
[Image: P9140581_zpsac7621f7.jpg]
[Image: P9140576_zpsbc6be529.jpg]
[Image: DSCN0232_zps73c3c4d8.jpg]
[Image: DSCN0231_zps50e5defd.jpg]
RE: 1986 TC Project - tcoupeturbo - 01-25-2015
Painted the short block with POR-15 Ford Blue, installed the Kevko pan using some Permatex Right Stuff. Installed ARP head studs, Felpro 1035. Installed the Esslinger water pump & billet intermediate shaft.
[Image: DSCN0255_zps7ac933f9.jpg]
[Image: DSCN0254_zps83ab1a0f.jpg]
[Image: DSCN0249_zpseeae9f29.jpg]
[Image: DSCN0250_zps13d60015.jpg]
RE: 1986 TC Project - Just Add Boost - 01-25-2015
Nice looking build! One thing I thought I would mention. Unless you are going carb, I don't think the MSD dizzy will work for you. They have no way to hook up to the factory fuel injection setup.
RE: 1986 TC Project - tcoupeturbo - 01-27-2015
Thanks for the compliments. As for the distributor, I am not running the factory fuel injection. I have a classic FAST system.
Ran into a little weather. Might be done for a little while.
[Image: DSCN0328_zps78969402.jpg]
RE: 1986 TC Project - Deathbypsi - 01-30-2015
Looks like a solid start!
RE: 1986 TC Project - tcoupeturbo - 02-04-2015
Because sometimes you need to turn left or right.
[Image: bca5c003-564d-44bc-90d3-4e315c047a30_zpsaf75772d.jpg]
Just receive my Griggs SN95 HD adjustable arms. I am looking forward to some better weather.
RE: 1986 TC Project - tcoupeturbo - 02-14-2015
Here are some pictures of my Esslinger D-port head. The port work was performed by, Tim Ottinger at Performance Masters. I was very happy with the customer service that was provided.
[Image: DSCN0295_zpscd4d7b39.jpg]
[Image: DSCN0294_zps0b44c13c.jpg]
[Image: DSCN0288_zps84367854.jpg]
Tim aslo went through the head and corrected several issues; low seat pressure, tight exhaust valves & a stripped thread. I can wait to get this together.
RE: 1986 TC Project - tcoupeturbo - 03-14-2015
I stopped by my Dad's & got a little time in on the engine today. Installed the oil cooler/heater, crank case breather, T-stat.
[Image: IMG_2032_zpsxjuxbmol.jpg]
[Image: IMG_2031_zpshv9pn7ni.jpg]
[Image: IMG_2035_zpsv83dg5ye.jpg]
[Image: IMG_2033_zpsle6tmnm5.jpg]
[Image: IMG_2034_zpsgvps98bl.jpg]
[Image: IMG_2036_zpslxjq5yl0.jpg]
