Pinto 4 speed to TC 5 speed crossmember adaptor ? - Printable Version
+- TurboFord (
https://turboford.org)
+-- Forum: Front Office (
https://turboford.org/forumdisplay.php?fid=39)
+--- Forum: Help, Feedback & Testing (
https://turboford.org/forumdisplay.php?fid=14)
+--- Thread: Pinto 4 speed to TC 5 speed crossmember adaptor ? (
/showthread.php?tid=80194)
2Beers - 09-06-2022
Help please.
I cant find the threads or information on the little extension 1/4 adaptor plate to extend the crossmember out a little for the TC 5 speed ...so it can work on the stock pinto trans crossmember.
I thought "stinger" had the little plate available to buy , but no luck finder it in the shop.
All help very appreciated in advance.
Thanks.
Ron
RE: Pinto 4 speed to TC 5 speed crossmember adaptor ? -
Jerry J - 09-07-2022
This is a link to a thread covering using a modified Pinto cross member.
https://www.fordpinto.com/general-help/t5-tranny-mount-pics-anyone-got-any-so-i-can-see-what-i-need/?topicseen
2Beers - 09-07-2022
Thanks Jerry J
Very appreciated.
I actually haven't seen this solution for the modification.
Looks way better then the other version where a 1/4 plate is used.
65ShelbyClone - 11-06-2022
All I had to do was elongate the crossmember bolt hole. I'm not sure if it would be different with a '74-80 where the 2.3 mounts are already on the frame.
