600HP dual plug motor part out -
onesillynotch - 05-26-2023
This is what im getting rid of at this time. im in Sloatsburg NY if you want to come see any of it in person. Car still ran perfect when i took it apart besides a hairline crack in #4 hole that i just happen to notice on an inspection.
Pimpxs-$700
Microsquirt-$225
Perfect tuning gauge $225
45 psi boost gauge autometer $ 65
2.5 stoker kit. Ranger Crank, Crower Rods, CP .020 Pistons- $1200
Treadstone IC and SS tigged piping for fox EFR/ front mount intake-$300
Ranger bracket and alt-$125
10an Mocal Sanwich oil cooler plate, lines, cooler $175
Canfield 5.0 bell adapter plate-125
Tremec 5.0 Bell- 225
Spec alumn flywheel 2.3/5.0 - $275
Ram powergrip HD 5.0 clutch 10 spline- $200
Hellcat pump on sn95 modified hanger (3/8 discharge) w/ 8an connection-$150
FOXBODY 100% SS Turbo custom exhaust..3.5” downpipe w/ vband cutout , 3” exhaust for the rest. Borla XR-1 muffler, Vband clamps thru, Vband Turbo inlet- $400
EFR 7163 Turbo w/ T25 inlet. Turbosmart dual port IWG, Turbosmart BOV/BPV combo. EFR speed sensor-$2200
Bo Custom requested design Header. 1.25 El with T25 Flange for EFR Turbo. $700
Bo Stage 1 Dual plug Head. Bo 2.5 Cam with custom upgraded springs, Esslinger RT Timing gear-$1500
Custom Dual plug sheetmetal intake. 65mm TB , 8an fuel rail. $1200
FID #1600 injectors $350
Turbo VC- $40
Areomotive Ford Rail style FRP $ 175
Kevco Block vent AN fitting- $25
Innovate MLX WB02 w/ 02 sensors -$140
93 Cobra BB and MC- $200
160MPH Fox non airbag speeder MOTORSPORT- $275
Ranger cam sync- $40
Custom wire harness. PIMPXS sequential injectors, Boshe ignitor, setup for dual MOPAR quad coil packs for dual plug. Lots of other sensor wires wired in also. Have CAD schematic to go with it. $200
email me for pics, details or questions!
matthewswanson15@gmail.com
RE: 600HP dual plug motor part out -
SVONOLES - 05-26-2023
Email sent...
onesillynotch - 06-25-2023
UPDATED!
Pimpxs-$700
Microsquirt-$225
ON EBAY
ON EBAY
Turbo VC- $40
ON EBAY
Golypon - 06-28-2023
Exhaust is sold then? It's halfway struck out.
onesillynotch - 06-30-2023
(06-28-2023, 04:31 PM)Golypon Wrote: Exhaust is sold then? It's halfway struck out.
im keeping the rear 3" for the new build. the downpipe is still for sale. 3.5" for an EFR. have 3" cutout in it.
all vband stainless tig welded
TurboRay - 06-30-2023
Can I/we ASSume that the “new build” will have more than 4 cylinders, Matt?
onesillynotch - 07-04-2023
(06-30-2023, 05:03 PM)TurboRay Wrote: .
8 cly ford DOHC, all motor! pump 93.
onesillynotch - 10-20-2023
updated 2023.10.20. prices lowerd, items updated
UPDATED!
Pimpxs-$700
Microsquirt-$225
Perfect tuning gauge $225 ON EBAY
45 psi boost gauge autometer $ 45
2.5 stoker kit. Ranger Crank, Crower Rods, CP .020 Pistons- $950
Treadstone IC and SS tigged piping for fox EFR/ front mount intake-$250
Ranger bracket and alt-$100
10an Mocal Sanwich oil cooler plate, lines, cooler $150
Canfield 5.0 bell adapter plate-100
Spec alumn flywheel 2.3/5.0 - $225
Hellcat pump on sn95 modified hanger (3/8 discharge) w/ 8an connection-$125
EFR 7163 Turbo w/ T25 inlet w/ EFR speed sensor and AN in and out fittings.-$1200
Turbosmart dual port IWG for EFR gen V, - 200
Turbosmart BOV/BPV combo for EFR or ecoboost.-125
Bo Custom requested design Header. 1.25 El with T25 Flange for EFR Turbo. $600
Bo Stage 1 Dual plug Head. Bo 2.5 Cam with custom upgraded springs, Esslinger RT Timing gear-$1100
Custom Dual plug sheetmetal intake. 65mm TB , 8an fuel rail. $1000
Turbo VC- $40
160MPH Fox non airbag speeder MOTORSPORT- $275 ON EBAY
matthewswanson15@gmail.com for quickest answers!
Function before form. Going fast is looking good!
Golypon - 11-09-2023
Emailed you
onesillynotch - 05-05-2024
Few things still around.
Boport stage 1 dual plug head (no cam) and Sheetmetal intake package deal $1200
Comes with fuel rail and 65mm explorer TB
Turbosmart dual port IWG for EFR gen V, - 175
Turbosmart BOV/BPV combo for EFR or ecoboost.-100
