HR980 Compressor needed -
Howard - 08-01-2024
Hi everyone!
I have been busy for a while, but am back to work on the SVO!
I really need a good HR980 A/C compressor, if anyone has one.
If not, what does everyone use to swap it out?
Thanks!
RE: HR980 Compressor needed -
Dolphin1 - 08-01-2024
Just to help some, if you go to the upullit and look for the parts from a 89-93 2.3 mustang you can use those parts to upgrade your a/c. you can also look on car-part.com for specific listings of parts that will work.
Howard - 08-01-2024
(08-01-2024, 11:33 AM)Dolphin1 Wrote: Just to help some, if you go to the upullit and look for the parts from a 89-93 2.3 mustang you can use those parts to upgrade your a/c. you can also look on car-part.com for specific listings of parts that will work.
Will that require changing from V-belt to a serpentine system?
Dolphin1 - 08-02-2024
Yes it would, didn't think about that. There are sanden compressors with a v belt clutch but you would need help from a a.c. Shop for the most part or a good parts counter guy. You could find the junkyard stuff and change the clutch to v belt as well.
Howard - 08-21-2024
I was able to get a NOS HR980 compressor from MikeC!
The comradery on this site is a tribute to all of Paul's work!
Thank everyone for all their help!
