I got a 83 T.C. and updated to a 87 engine. I want to use the 83 T3 turbo instead of the ihi one. How do you get this setup to work with the intercooler and hood?
You have to grind off the flange on the t3 outlet or get a SVO t3 compressor housing... and it should slip on the t3 then... the hood you can just take off the 87 or if that hood was no good find one in a junkyard from a 87 or 88.. the tc hoods all fit the same...
if you just grind the flange off the t3.. you will have to rotate the housing a little so the ic will fit right...
