yes if the car idle is not setup right then you will need to bump it up..your idle should be were you want it with the plug out then you plug it back in
Function before form. Going fast is looking good!
Quote:Originally posted by 76Capri:
Quote:Originally posted by goland55:
[b] So unplugging it will keep the valve shut? If so I might try doing that and see what it's like.
You'd have to unplug it as you revved the engine to ensure it is really closed...right?
It's a motor and it should stop at whatever posistion it's unplugged at and stay there...Could be wrong. :dunno: [/b]
It isnt a motor as such.... it is a solenoid driven by a 40 Hz PWM signal. Unless stuck in the open position, with electrical connector off, it is closed.
Jeff Korn
86 Tbird 5.0 - lots of mods / 88 Turbo Coupe - lots of mods / 05 Taurus Duratec / 04 Taurus Duratec (wifes) / 02 Grand Prix GT
Mine runs fine, and it's quite awkward... Mines disconnected, and the idle is set manually.... I've started it on 40 degree mornings without a problem at all.... What is kinda funny, WITHOUT THE IAC HOOKED UP it will idle at about 800 (Where I have it set too) Other times it will idle itself up to about 2000, a couple seconds later it immediatly drops back down to 800.... :dunno:
I have done 3 xr's now and blocked off the iac on all of them.I'm in ohio so it gets cold but after the frist little rev it will idle itself no matter what temp is.I have the cars setup for not running it though.The idle is turned up to 1200 and the tps is set for it also.One of the best mods,death to the iac.
Eric
Hellcat 17psi daily lol
GT500 11.6 @ 126
CruzNLife1: That 2000 RPM problem is probably caused by a bad TPS.
at the risk of seeming dumber than i am is the iac the same throttle air bypass?
thanks
bob
bring back muscle cars-ban low performance drivers
guns dont kill people- drivers with cell phones do
Thanks for the info Jeff K. I guess that's what makes it different from a set motor design.. I am correct that the step motor idle air control will just stop where it is when unplugged and not close...right??
76 Capri II turbo
The only change I see is the
altitude we are at as we head further into the downward spiral
yup... Idle Air Controler
84 SVO... back on the road....
aha! i have in my possession a idle setup that comes from ford. it fits between the iac and the tb. it has 2 idle adjust screws. i assume that is made to basically do away with the iac.
bob
guns dont kill people-drivers with cell phones do
Huh??? :dunno:
Brad
'88 Project DPDISXR4Ti
MerkurClub.com
