12-30-2003, 11:01 PM
Ok for any of you 83-86 TC (and other Foxes) owners who don't want to swith K-Members , or spindals but want the 5 lug common pattern READ THIS!
This is a cheap way to swap to the 5 lug pattern and not break the bank. So this is info given to me by other members and I thought I would compile it and pass it on. All the info may not be 100% correct or accurate. If anyone has info to add please do! :tfrules:
Ok so ya got this
[Image: Ranger%20Rotor%20002.jpg?dc=4675453533979493187]
[Image: Ranger%20Rotor%20003.jpg?dc=4675453533983269577]
-First you remove the wheel
-Compress the brake Pad back to its furthest most location
-remove the brake caliper bolts and pull the caliper off
-take off the dust cap
-remove the cotter pin, nut retainer, and nut
-Pull out the bearing
-replace the nut threading it on a few twists
-slide the rotor down and use the bolt to remove the oil seal and bearing by lightly tugging on the rotor until the bearing and oil seal pop out.
- reinstall old bearing, oil seals in new Ranger rotor
-install rotor
-put the outer bearing back in, with the washer, and nut
-snug up the nut, add the retainer and insert the cotter pin
-Reinstall brake parts
Completion! Ok you will notice there is very little room with the stock TC caliper with the ranger rotor BUT it does Fit! It feels nice and snug with no clearance issues. Although it is tight! See the feeler gauge! You will also need a new Dust cap. I may personally still make some modifications to allow for a little more clearance.
[Image: Ranger%20Rotor%20011.jpg?dc=4675453533991048240]
[Image: Ranger%20Rotor%20004.jpg?dc=4675453533986276054]
Ok so ya got this
-install rotor
1986 TurboCoupe and tons of Jeeps
