is a mustang 5.0 cable the same as a mustang 2.3?
1988 turbo coupe
I am sure it will work.I know of guys who use the 5.0 clutch quadrant/cable kit on svo's and tc's with no problems.
84TC-gutted intakes-80mm maf-944 FMIC Greddy BOV 72lb inj
PPbig valve head-255LPH kirban-20psi-17"cntlines-65mmTB full 3" exhaust-on the way to 400hp
thats the funny thing. i tried to put a mustang cable on my 86 xr7 and it is about an inch short and is has a threaded end where-as the stock one has a "ball". but i am making a custom bracket, so as long as the pedal has enough throw. but it certainly isn't bolt-on.
jonathon
1988 turbo coupe
The 5.0 uses a cable that is different from the later 2.3's. The 2.3's with the "dogbone" style linkage use the type with the ball on the end that slips into a clevise that is linked to a 2" cable that actually works the clutch arm. Some (maybe all?)of the svo's and early tc's have an earlier 4-speed style bell that uses the same cable as the 5.0 with the cable connected directly to the arm. I have used a later cable on the older bellhousing with a bushing I fabbed up, but have never done it the other way.
86 SVO 1D
Here is an adapter I made to run a 5.0 adj quadrant & cable on my Turbo Notch...
I made it from part of a throttle linkage from a 400 Cummings...
[Image: quadrant_adapter.jpg]
When my new clutch goes in it will be with an SROD bell the way it should be...
Any sufficiently advanced technology is indistinguishable from magic. - Arthur C. Clarke
