Hey i was wondering if there are 3 aluminum heads avalible from Esslinger now?..I know they had the ARCA head and the New NASH head but is the SVO head differant from the ARCA?..i know the SVo used to advertise with 1.89 and 1.59 valves,and i see the ARCA says 2.02 and 1.60 valves?..did they revise the SVO to flow more or is it the same head with bigger valves?..........i figured id let you all laugh at me before i Email Esslinger..........Hal
Be polite to everyone,trust noone, above all have a plan to kill everyone you meet.Greet everyone with a smile on your face and homicide in your heart
i *think* the svo and the ARCA head are basically the same casting just the ARCA head is CNC ported to the max and with larger valves...
"there is no such thing as a stupid question, just stupid people"
PICS OF MY XR, FOLVO STUFF, AND...
Esslinger actually makes 4 different aluminum heads for the 2.3-based motors:
- SVO (the original)
- ARCA (SVO casting, but CNC machined with larger ports, as pyropete125 said)
- Midget (different casting with 5 cam towers)
- Street/D-port (stock replacement head that accepts the factory intake and has provisions for mounting all the OEM accessory brkts)
C'ya - RAY
(former) '78 2.3T Courier w/blow-thru Autolite 2bbl carb ~ (current) '87 2.3T Ranger w/PiMP’d EFI
So the SVO doesn't have accessory bolt holes?
Not quite running yet '72 2.3T T-5 Pinto runabout.
thanx for the info..I totaly forgot about the 5 cam tower head and i have an article about it right here............Hal
As far as I know, nobody has ever really ported one...LOL
They do what you might refer to as "assembly line" cleanup behind the valves, to blend the casting to the machined seats...and it flows 238 at 28"...out of the box. Maybe that's all it's gonna get, but it would be the first head ever that couldn't be improved.
I don't care what some of the wanna-bee head-hackers on here say, you ain't gonna get near this head with an iron casting, the port has been moved out to where there's only H2O in an iron head.
