Oil return thread?
I need to know what size the thread on the end of the IHI oil return is. The actual line not the spacer that goes into the block. Thanks
1/2 npt i believe
Nada...trying to turn mud back into DrPhang.
Well I know the one for the block is 1/2" and I just compared the block spacer to the line and they were close but the threads on the line are smaller
i believe the garretts use 1/2 pipe thread. the ihi might be one size smaller, 3/8 pipe thread. just guessing though, as i havent seen one of those. if you have any pipe fittings around, try screwing a few of them into it to see if any fit. failing that, take it to home depot or similar and do the same thing Smile
Jason, Merkurboys
86 Silver XR4Ti. MS3. 12.7@111
03 Red VW Golf TDI
I went to the hardware store today and they couldn't figure out what size it is. Does anybody know for sure what size it is?
ttt
Users browsing this thread: 2 Guest(s)
