Neongreen --> :cheers:
I don't have any pictures with this update, but I have made a little progress.
I drilled the top alternator mounting hole, threaded it, and installed a heavy duty thread insert. Now, the studded heim joint threads into the alternator. I also believe I have the OEM wiring harness finished up now. I removed anything that wasn't necessary. I will need to hook up the respective wires to ground, battery power, and crank/key on power. This will allow me to start the car on the OEM computer. I am always nervous messing with wiring harnesses like this. You never know if it'll work until it's time to crank
Now that the wiring is done and the accessories are mounted, I need to start on the fuel system. Here is what I ordered:
Part # Item
20 gal Fuel Cell (already installed)
AER-FBM1443 90 DEG ELBOW AN SWIVEL #8
AER-FBM1513 FITTING 8AN-TO-BARB STRAIGHT
AER-FBM2083 BULK HEAD FITTING
SUM-220839 -08 BULKHEAD NUT ALUMINUM
SUM-220846 8AN TO 3/8 NPT ADAPTER
AEI-12316 JD FILTER IN-LINE
SUM-220648 6AN TO 3/8 NPT ADAPTER
AER-FBM1222 #6 Brass 37. female swivel
RUS-670470 10MM x 1.0MM TO -6AN
VPN-GSL392 WALBRO ELECTRIC FUEL PUMP
ACC-74720 FUEL FILTER
EAR-592406ERL BULKHEAD NUT -6
AER-FBM2072 BULKHEAD UNION -6 FLARE ENDS
SUM-2200077 -6-3/8 MALE HARDTUBE FITTING
RUS-640900 EFI ADAPTER FORD -6AN PRESSURE
Fuel Rail (already installed)
RUS-640870 EFI ADAPTER FORD -6 AN RETURN
EAR-983306ERL -6 90 DEG. BULKHEAD FITTING
AER-FBM1232 HOSE BARB 8AN - 6AN
AER-FCV0610 10' #6 AQP SOCKETLESS HOSE
SUM-G2538 ALUM TUBING 3/8" X 25FT
EAR-992908ERL -8 CAP
FRA-481906 TUBE SLEEVE
I hope I ordered everything I'll need. It took quite a while to figure all that out
So, here is what's left:
-- Install fuel system
-- Clean up wiring harness and engine bay wiring
-- Radiator hoses
-- Change oil
-- ??? I think that's it!!!
Have a good day!
