86 SVO project.
    Found this little baby in a garage. Had been there 17 years. 42k miles were on it, so were the original tires. So far it has a cold air kit, dual 2 1/2" catless exhaust, Series 40 flowmasters, SPEC Racing light weight flywheel and clutch. Adjustable fuel regulator. If you can believe the boost gauge, runs about 20psi max. I've got a few other things planned, but so far this it after 3 years.
40 year tech
86 SVO mostly stock, so far
