Alternator Location
I have an 89 merkur engine with a 93 serpentine belt system. I am looking to relocate my alternator to the passenger side and keep the current power steering setup.
Does any know if this is possible? If so, what year/make bracket? I have looked around and found some but for vbelt systems.
Thank you
The images are gone, but: http://forum.merkurclub.com/forum/viewtopic.php?f=44&t=12217&hilit=ranger+alternator
Attachment is from my 2009 Pinto build.
Mike
Attached Files Thumbnail(s)
'78 Fairmont boxtop, Stage I head w/2.1 cam, LA3, Kirban, SN95 4-wheel discs, driving & building
(01-31-2020, 12:21 AM)4-barrel Mike Wrote:  The images are gone, but: http://forum.merkurclub.com/forum/viewtopic.php?f=44&t=12217&hilit=ranger+alternator
Mike
Mike the link goes to the merkur forum but it states the info is no longer available. Did you use an a/c bracket? or is it a specific year alternator bracket from something else?
Strange, normally I check to make sure that the link works.
This one is tested:
http://forum.merkurclub.com/forum/viewto...alternator :)
Mike
(01-31-2020, 01:45 AM)4-barrel Mike Wrote:  Strange, normally I check to make sure that the link works.
This one is tested:
Mike
Thank you!
