11-12-2024, 06:34 PM
(This post was last modified: 11-12-2024, 06:35 PM by
Alpine615.)
Hey y'all, I'm looking for the block plate for an automatic transmission, part number E3TZ-7007-B. Anyone got one they'd be willing to part with? I might also be interested in the torque converter access cover as well.
Thanks!
-Steve
80 Pinto Runabout
11-14-2024, 02:07 AM
(This post was last modified: 11-14-2024, 07:50 PM by
TurboRay.)
DUNNO if
THIS (<--- link) is legit or not...... you might find that the listing is no longer valid since that part is NLA from Ford's current parts catalog. Alternatively, you could look for a stick-shift separator plate (E3TZ-7007-
A?) and access the converter nuts thru the starter hole. AFAIK, ANY Lima separator plate should fit and work. The main reason they're needed is to precisely align the starter with the ring gear. <shrug> GOOD LUCK!
Thanks Ray, but I reached out to Chip Givens and he was able to hook me up. 👍🏻
80 Pinto Runabout
11-15-2024, 04:43 AM
(This post was last modified: 11-15-2024, 08:02 AM by
TurboRay.)
