better brakes
I am taking the rear out of my 88tc and putting it in my 89mustang and the motor. I want to also improve the brakes but i do not want to use the disk brakes off the tc because i dont want to bother with a adjustable porporshing valve. what brakes can i use i want to up grade front and back what car should i look for in junk yard i have not seen a 5.0 mustang in any of my local junk yards so what other cars would be good
85SVO 2.0 ecoboost, s200, MS3
putting the valve in is not that big of a deal. It is a very easy swap plus u already have most of the parts.
87 mustang LX turbo
megasquirted
5.0s? Brake upgrades?!?!
BwAAHAHAHA... ahem... pardon me.
http://mjbobbitt.home.comcast.net/index.html
http://www.corral.net/tech/handling/tech_brakes.html
The adj prop valve is easy. There is a butt connector in the rear line upper passenger side of the firewall. No need to flare lines or anything.
Horsepower is like sex & money...to much still ain't enough.
I'm confused, you are putting in a TC rear but don't want the disc brakes? What do you think you're going to put in there? The TC rear brakes are about the best thing you can get aside from a big bucks Cobra brake kit from Ford, if you can get it to fit.
My tip is to redo all the pins in the calipers, you will thank me later when you don't have to put new rotors on.
John Lewis
84 SVO - 50 Trim 16V IRS
Now with Megasquirt I Extra V3 PCB
