boost controler
what the best/cheapest boost control that will get the job done?? is there anything i can easily makeshift to do it myself
Team P.A.S.S
Weapon X_____________'87 Merkur x4rti (2.3 turbo)
Wulvereen____________'87 Mustang lx (2.3 turbo)
Korn_________________'64 Auston Healey 3000 (chev327)
TheFaceLessBaller____'88 Thunderbird (hoped up 5.0)
Looking for new Turbo Project...
Under new management - 1987 Merkur XR4TI http://www.cardomain.com/memberpage/471096
Well, I orderd a boost valve from boostcontroler.com, HOWEVER, the customer service sucks. Ya'll may wanna disagree with me, but if you do, you'll be waiting for 8 years like I have.
*something witty here*
This one works really well - it's about 45 bux. [Image: smile.gif]
hey, s it just me or did ric change the style of his boost controller? if so, i like that method of mounting/design alot more than the average boost controller. i mgh break down and buy one if my 18 PSI isnt realized here shortly.
LA3 computer, 16 pounds of boost and 4.10 gears. this makes a good starting point. soon to come: a 13 second timeslip
Euphemistically challenged
There are definately cheaper ways to make a boost controller, but the type of boost controller Ric makes works excellent. I used to run a cheap bleed valve on my 2.3L Turbo and always saw about 2psi worth of spike before settling to the set amount of boost.
I've got Ric's valve on my Eclipse Turbo and get a rock solid 15psi with not even a hint of a spike!
I just made a relief valve shown to me by "Hamsterbation"I have 12 dollars in it total.No spike no creep,and it holds 19psi steady.
1985 Merkur XR4Ti(project)
YES, YES, make one! The Gillis valve, sold at boostvalve.com is an excellent valve, and easy to make! I posted this very question a coupl of weeks ago, and people graciously responded with links to buily your own Gillis valve. I did it, and it works great!
Here is the link to my previous question. I followed the instructions on the Grainger Valve, and it is sweet. Happy boosting! http://www2.turboford.org/techboard/ubb/...07310.html
88TC motor in a Chenowth SV-16 buggy. LA3, 3" stainless exhaust, Accel coil, K&N, Gillis Valve, Esslinger water pump, timing belt tensioner, and cam pulley.
HERE'S the link for makin' it yourself, if you'd rather not pay the $45 for one that's well made! [Image: frown.gif] If you DO decide to do it - I'd make it the way Rick Gillis does, with barbed brass fittings instead of the plastic ones shown on the DIY site. [Image: smile.gif]
Thats exactly the way I made mine (with the brass fittings). We cut off a fitting, and drilled a hole in the side of the relief valve, and silver soldered the barbed fitting onto the side of the valve. Works sweet, and looks exactly like the Gillis valve. We also soldered up the hole in the end of the adjustmnet screw, and drilled a 22 thousandths hole in that, for bleed off, as mentioned in the instructions. Works awesome! Thanks again, guys.
http://www.geocities.com/nmudl/pics/mods/MBC.jpg
thats what im gonna play with when i get my 'bird [Image: smile.gif]
