05-17-2005, 09:38 AM
I just got done with a fresh Dyono and feel the torque and HP levels can be brought up by tweeking the cam and ignition settings.
The combo link is here.
http://www.turboford.org/ubb/ultimatebb....3;t=016303
The initial cam setting is straight up, and the base timing was 6 deg adv.
I figure maybe not messing with the ignition, by suggestion of my tuner man.
But, through reading up a bit I may be able to increase the effective torque by retarding the cam a bit, I'm hoping this wil lower the exhaust pressure within the cylinder a bit.
What can you guys suggest, from your best settings, to help save some time on the future Dyno pulls.
89 Notch: 85 1/2 SVO
