Can you get new clips that hold the clutch cable to the fork linkage?
Finally found a almost complete 2.3 t5 bellhousing. Brought it home and realized I’m missing the clips to connect the cable to it. Is there a replacement  for new ones or any ideas for a home made one?
I might be able to find one locally also, that’s a maybe though.
Success!!!! Kinda
Missing clip..
Is this the clip/link you're looking for, Ian? [Image: happy0024.gif]
[Image: mXyadr4.jpg?1]
If so, you could trying Googling the Ford part number (altho I'm pretty sure they're NLA from Ford). You could also search on eBay for an NOS version, OR.....you can get 'em under the dash of many Ford cars and trucks......since they're the same clevises used to connect the E-brake cable to the foot-operated pedal assemblies. [Image: happy0034.gif]
(former)  '78 2.3T Courier w/blow-thru carb ~ (current)  '87 2.3T Ranger w/PiMP’d EFI
(02-02-2020, 07:31 AM)TurboRay Wrote:  Is this the clip/link you're looking for, Ian? [Image: happy0024.gif]
Ray that sure does look like that part I needed. Doesn't look its in production anymore, however I might get lucky at the same pick-n-pull I was just at. Just be a matter of finding a vehicle there with a foot pedal e-brake.
Also missing the clevis pin which is not available either however I believe I can find something out there...hell I dont know how much faith I got in Harbor Freight metal but even this will work in a jam...
https://www.harborfreight.com/74-piece-c...67629.html
