01-15-2017, 02:23 AM
I wanna thank mgman75 for helping me get this far.
http://forum.turboford.org/cgi-bin/ultim...059504;p=0
Now it fires right up, runs for 2 seconds then dies! I've got 40lbs of fuel pressure at the rail (fp gauge on the rail). Just replaced the TFI too. It's gotta be in the wiring. '89 Mustang N/A harness modded for VAM/boost/bap/etc. Worked fine for 4 years on Thunderstang. LA3 ECU. Generic ignition switch. It starts but seems like the ECU isn't allowing it to run. Power runs from the BATT to the starter solenoid to a terminal block to the ignition switch. I've traced the wires a dozen times. I have wiring diagrams and EVTMs. Here's pics of my starter solenoid, terminal block and ignition switch.
STARTER SOLENOID.................
[Image: Starter%20solenoid_zpshlhnihxy.jpg]
1) Circuit #32 to TFI
2) I added this wire. To center stud (start) on ignition switch.
3) Hot at all times. Power wire to terminal block.
4) Circuit #38 to EEC relay.
5) Circuit #36 to alternator plug. 3G conversion.
6) To alternator power output stud. Fused.
7) Main POS battery cable.
8) To starter motor.
TERMINAL BLOCK...............
[Image: Terminal%20block_zps2fq0epbu.jpg]
1) BATT power to fuel pump relay.
2) BATT power to fan relay.
3) BATT power from starter solenoid.
4) BATT power to ignition switch.
IGNITION SWITCH..............
[Image: Ignition%20switch_zps0xdlxtk8.jpg]
1) Hot at all times from BATT stud on terminal block/solenoid.
2) Circuit #16 to TFI/Coil/EEC relay.
3) Circuit #687 to O2 sensor.
4) Power wire to fuel pump relay.
5) To small top stud on starter solenoid.
There are 6-7 wires I eliminated from the harness but they shouldn't have anything to do with the running of the motor. I'm turning to you guys 'cause I have no more options! I've gone as far as I can go. I need expert Turboforder's help!!
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
Thunderstang (DECEASED)
'27 Model 'T' w/2.3T
Proverbs 3:5
