DIY Adjustable FPR (AFPR)
(11-20-2022, 11:36 PM)TurboRay Wrote:
(11-20-2022, 02:31 AM)Wyatt Wrote:  This seems like a good budget option.  The question is how to best modify it for boost reference.
No need to modify it, Wyatt......the adjustment screw is already drilled. Simply slide your manifold-reference hose over the screw AND nipple into which it's threaded ~ and you're done.  <thumbup>
[Image: 51k6Z9idpaL._AC_SY580_.jpg]
If that doesn't work you could try plugging the hole and drilling the side for a nipple like this.
  [Image: pinto%20025.jpg]
1978 Pinto wagon 13.1 on a 175/13 all season tire!
(12-26-2022, 03:11 AM)Glassman Wrote:  If that doesn't work you could try plugging the hole and drilling the side for a nipple like this.
That looks good, GM<thumbup>
Thank you Ray. It burned up in the great Pinto wagon fire of 2011.
