EEC Tuner cable and PS question
do you have the colors for the RJ45? or which one is #1
but yes it helps out alot..
Thanks
Steve
google is my friend..here is the colors for the RJ45..
Also #1 on the RJ45 is on the left side when you hold the connector with the clip at the bottom..
1 wh/or
2 or
3 wh/grn
4 blu
5 wh/blu
6 grn
7 wh/brn
8 brn
Thanks alot guys
Steve
Quote:Originally posted by dolphin1:
the power supply i use is 9 volts 350 ma.
i think i found one just one last question. is the center of the plug the + and the outside the - ..
Thanks
Steve
I recall the ps uses 9v 500mA, the center pin is
pos., cost about $20 at radio shack.
Thanks for all the help guys,the above info was dead on and it worked perfect.Made the cable and i verified the Tuner was in perfect shape.It even still had my old PE file i used on the ranger..
Now i'll post it on the for sale section..
Thanks again
Steve
