06-27-2019, 01:08 PM
If you have this turbo and have oil control issues please read. I had smoking for 2 years as soon as the oil warmed up. We are talking fill the turbine housing with a puddle kinda oil. kill all the bugs. make kids run indoors. embarrassing to drive kinda smoke.
ill spare the 2 years of on/off testing everything but ultimately it was the turbo infact needs a restrictor . You can only get this restrictor from Germany at the moment but it came quick.
This even came after using TurboXS inline turbo oil regulator that sets oil pressure to 40psi to the turbo and running a 10- to -16 to 1"NPT drain hole in the oil pan!!
https://www.turbozentrum.de/Oil-Feed-Ada...ictor-07mm
is the one i have right now. Stock built in restriction is 2mm. This is .07mm...i also have the 1.6mm that i will try to see if it still doesn't smoke
this is after running a 6258 for years, littlerly had one of the first ones and always loved it with never an issue like this.
so if you have this issue, ignore the documentation, shoot them a call discuss!
I love these EFR turbos and id rather put it out there then people just give up! Keep in mind this is the only turbo in the lineup that i know or can find info on for having this issue. Its the only turbo also that im aware of in the small frame but aluminum center section. The others i this frame size are steel center sections.
Function before form. Going fast is looking good!
