Help me pick my next mod!
I am trying to decide between a few mods. what would you pick?
first- EEC tuner
second- T40B/T3
third- A237 cam swap
fourth-nitrous kit
Fifth-custom header
shawn
My vehicle
1983 Turbo Coupe with a GN intercooler, dawes device set at 22psi of boost,K&N cone,fully ported e-6 manifold,gutted and ported intake, ported stock valve head, Ranger cam set -2 deg, and Full 3" exhaust with 3" magnaflow, 190 pump, a TRI AX shifter,Madhatter clutch quadrant,Racer walsh adjusatble cam pulley large VAM, LA3, brown tops, and 88 TC wheels. Next mods, boxed control arms, Subframe connectors, 3.73 8.8 rear,Larger front brakes, and poly bushings. Then i have no ideaSmile
has run a best of 14.71 at 92mph on drag radials. New times with GN intercooler, LA3, brown tops!!!! 14.9 at 96mph on my street tires.
New times with head ,e6 and ported intake, 100 race fuel, and 28psi 13.83 at 103mph!
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
3tc powered sandrail.
i'd go for the cam. you did say that you thought it was pushing it's limits, didn't you?
88 LX NOTCH (For sale)
88 LX NOTCH Turbo(For sale)
93 LX NOTCH Turbo (For sale)
90 GT convertable
This is an easy one! I say a good clutch!
I have seen impressive things with the tunner. I saw Gators car pick up 23-24 horse. I just think it would go a long way at fine tunning the combo's once they are too far away from stock to be able to correct with the stock computer. Besides, it will still give you adjustability for what ever you want to do next, and it is almost the cheapist.
Newbie with dumb newbie questions...
some wiring diagrams and by some , I mean none at all.
1984 GT350 T-top New pics
1984 Turbo GT T-top 419rwhp
Go for the cam or the tuner. It's a close call though, I don't think you can go wrong with any of the choices.
cam, tuner, go go juice, turbo last,,,,,
Well, seein' as how you were runnin' "way lean" on that last dyno pull with 78psi f/pres and brown tops - it had better be the EEC Tuner!! [Image: smile.gif]
Nitrous, nitrous, nitrous. lol
But seriously, I would get you these done first off boxed control arms, Subframe connectors, 3.73 8.8 rear. You have so much left in your combo now, 13.83 @103. I have ran in the 12's with 103. I would get it hook'n and scoot'n first. Do you really want to have tell everyone your 300 rwhp car runs mid 13's?
Later, and those are some kick @$$ numbers, makes me feel good to. lol
Randy
Later
Randy
87 Mustang coupe 3100# with me in it
Stock bottom end, home ported head, with stock valves, home ported lower, gutted upper, home ported E6, single 3" exhaust, Ranger cam--retarded 4 degrees, 255 intank with #6 lines, Aeroquipe FP regulator, la3, k&n, 87 tc 5-speed with 8.8 and 3.55's, stock 86 TC 5-speed turbo running 20#, starion front mount IC, underdrive pulley, msd Digital 6 - only help with the launch, 6*10.5*15 E.T. streets
Best on motor
1/8th 8.10 @85mph
1/4 12.79 @105.64mph
Best on NX 50-shot
7.70@ 90mph
12.12 @ 113
85 2.3turbo Rx7
10.88@125.6-no nitrous yet Smile
Dead and crushed Sad
82 Toyota Starlet KP61
pushrod 4cyl
10.47@135 on dots
Thanks, I already plan on doing these mods first, Plus a WC t-5 and a star clutch. I am just trying to figure out what engine mod to do next.
So is it the computer that is holding me back now? I have been thinking about using a PK1 or something and an EEC tuner. I guess then I could try those 52lbhr injectors I just picked up(no going lean with these eh).
thanks guys! keep the good info coming!
Shawn
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
Turbo upgrade.Your hogged`6 should continue to serve you well.Randy`s right about suspension.Good rear control arms.EEC-4 Tuner not far down the road.
[This message has been edited by Jon J (edited 12-02-2001).]
I would go tuner first, as it will give you adjustability now and down the road. This then will let you know whether you need larger injectors or whatever. Cam and kit (roller preferred) next as you then can tune for the cam. Then rear end mods and sticky tires to hook up with. Adjustable rear shocks might help to dial in the launch and then adjustable front struts set at 90/10 to get weight transfer if needed. Why not gear for a 3.00 final ratio with the 5 spd overdrive. 5th ratio (.60 x 4.56=2.73 final ratio)(.60x4.88=2.93)(.70x4.56=3.19). My 86 TC with auto is 3.45 and gets 25 mpg. See ya later, Dale
