How many qts in your pan??
This is a poll to see if anybody has the right amount of oil.Ford has a bulitin that 2.3 turbo cars have the wrong dipstick highth.There should only be 5 qts in the pan.To corect this ,at your next oil change put 5 qts in start car turn off check the level.99%of the time its about a qt low.Mesure this distance,then cut it off the tube.Now the level is corect. Big Grin
What do u get when u feed booost to a dinosaur???? Booostalotopuss.T for Turbo-S for Supercharged.
what happens when your pan holds 6 qts ?
Lemme correct that....what happens when your pan is supposed to hold 6qts ? Big Grin
"You have been by far the MOST worthless to the board moreso than any other member." - GT350R
what happens when your car already has the proper dipstick, which the TSB specified for replacement?
if anyone cares...ill get the part #s at work tomorrow, as well as a list of affected 2.3's
-james
Out of all the 2.3's I've owned, I never had a problem until my latest 88 XR. It shows a quart low. :dunno: Thanks for the info
My old 84 TC dipstick read right but the 88TC dipstick reads 1 qt. low.
84TC-gutted intakes-80mm maf-944 FMIC Greddy BOV 72lb inj
PPbig valve head-255LPH kirban-20psi-17"cntlines-65mmTB full 3" exhaust-on the way to 400hp
I have a Snap-On scaner that has books to show some builltens.One of them is for the oil level on the 2.3 turbo motors.It says that the tube is to long,before i found out this i was useing 6 qts.I was just thinking of this the other day,so i had to share.Like i said it is only for the 2.3 turbos.Tomarrow i'll try to get all the codes + what they mean & how to test 4 that code. :cheers:
Funny story now I suppose. When I bought my black merk. I drove it around for a week after getting it. Well one day it started puking black smoke out the tailpipe. Well I later came to find out it had 13qts of oil in it! Which caused the pcv valve to shoot shit and suck up the oil into the intake. :crazy:
A few cars in the garage. Wink
OH MY GOD.That is a horrifing story.Sounds like the last owner did 2 oil changes did new filters and never drained it.It nice to know you save it from someone how whould have killed the car. :worshippy:
Yea the people I bought my xrs from were friends. They tried but they just didnt have it in them on these cars.
My 85 Merk shows a quart low on the stick (too short) great quality control...
85 XR4Ti 5spd "I'm not REALLY a "WING Commander"/"Geschwaderkommodore " but I do play one in my XR."
