IHI Lower Coolant Line
I destroyed my lower coolant line off the IHI turbo yesterday while taking it off.  I am looking for a replacement now and if I can't find one will make one to fit.
One of my questions:  Is it normal to have a hose on the end to connect to the block (same for the one up top)?  If this is the norm is it a special type of material?  Seemed different hose wrapped in a fabric.
Thanks,
Mike
Here is a picture (I am trying to attach it):
Attached Files Thumbnail(s)
What's up Mikey, yes that's how mine looked. I used a NPT to compression on the turbo, with a coated brake line bent to the return, some rubber hose (1/4 maybe), and a brass nipple x NPT in the block.
88 TC in Canyon Red
Walbro 255, AEM wideband, CP Pistons, FMIC, PIMP, SVO T3, Ranger roller, 3" Stinger exhaust, AFPR, RFL BOV, Gutted upper, Ported lower
I used silicone reinforced heater hose on my T3 coolant return.  Bought it at NAPA auto parts.  It's stronger and more protection being so close to a heat source (turbo).  Here's some in 1/4" diameter...…
https://www.summitracing.com/parts/vpe-20405
You can see my NAPA hose in blue right next to and below the turbo.....
[Image: kgjUGRil.jpg]
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
Thunderstang (DECEASED)
'27 Model 'T' w/2.3T
Thank you ThunderFaux and evintho.
evintho - Beautiful and clean! I would like to see the rest of the car.
Thanks!  Here's the build thread...…
https://turboford.org/thread-my-27-model...orce-fed-4
[Image: Z4l3KSzl.jpg]
Proverbs 3:5
