IHI to T3/4 upgrade, Oil return line question Is it true?
Quote:Originally posted by toprunner:
When I upgraded my 87TC the original return line matched up perfect on the T3.
Every one I've seen in the junkyards are the same, no matter IHI or T3. In fact the return line on my T3 came of an IHI from the junk yard.
Lon
1985.5 SVO
I've got both RETURN LINES (not small ss feed lines) in front of me and there is no way an IHI line fits a T3, the flange is WAY smaller. I'll try to take a pic of them sometime.
Stinger
|STINGER PERFORMANCE| 2.3T Parts, Swap & Tech Articles |FAQ| -FORUM-|
|->PiMPxs & PiMPx ECU\'s<-| SVOx3, Turbo 06 GT
Wow! now I'm more confused. Well, Stinger, if you could post pics that would be cool. I trying to hve everything ready for the hybrid install.
88 TC, T3/4, Forge BPV, K&N, RR+, int-E6-big valve head,work, StageIII, 255 Walbro, Kirban, 3", subs, 55lbs, 2.5 dual, Tuned EEC, 80mm MAF, frt mnt.
Doesn't look like it fits to me Wink
[Image: Proof.jpg]
Stinger
IT DOESN'T FIT!!!!!THE IHI RETURN LINE HAS A SMALLER FLANGE.
84TC-gutted intakes-80mm maf-944 FMIC Greddy BOV 72lb inj
PPbig valve head-255LPH kirban-20psi-17"cntlines-65mmTB full 3" exhaust-on the way to 400hp
#16
As shown in my picture above :thumbup:
#17
don't know what to tell ya. I pulled a return line off an 87 T-Coupe with an IHI and put it on my stock T3 in my SVO. Maybe the car I pulled it off of had been modified sometime in it's life? Or I was wrong and just thought it came off an IHI (I did this right after I got my car and didn't know alot about non-truck turbos back then).
Lon
1985.5 SVO
#18
I made an adapter for mine. Email me at beydler@juno.com for pics. :tfrules:
#19
Guys to settle the matter I would say there may have been a running changeover in production since there are discrepancies between what we all have. Eric, if your's won't match just get on from an 86 with a T3.
88TC T-5,T3/T4,stageIII/.60 trim, A237 cam, gillis valve, hi-flow exhaust,140 speedo
