06-24-2005, 09:08 PM
Before I swapped in the walbro 255 my gas gauge worked fine. When I swapped it in, I kept the sending unit plug, the circular one with the two big prongs on the side. But cut off the other one and taped the wires and tucked them away.
My gauge is now nonfunctional and the warning lights for everything come on on the center console above the radio.
I was reading the shop manual and found that the one I cut off had "gauge ground" on one of the prongs. So I figure I would just have to pull out the tucked wires and ground one of the two brown wires in there. I tried that and still haven't figured it out.
Should I pull the tank, crimp the plug back on, but leave the power wire off, and plug it back on? Will that fix it? Just asking so I don't waste time dropping the tank.
01 Cavy Coupe - Slow
88 XR4Ti - Less Slow
