MM Panhard Bar Exhaust Fitment
Quick Question,
Anyone running a MM Panhard Bar setup with a 3" single Exhaust? Worried I am going to have fitment issues but hoping someone has already addressed this.
Ryan
1969 Mach I Mustang
1985 GT T-Top:
LA3, T3, Walbro 255, Stinger FMIC, RR Cam w/Esslinger adj. sproket
I have the MM pan hard bar in my SVO with 2.5" exhaust.  It is a tight fit with the 2.5" tail pipes, so I think the 3" would be problematic.  Give the guys at MM a call.  I'm sure they have run into this before.  As I recall, you have to use the Dynomax 2.5 or the flowmaster 2.5 tail pipes to clear the bar.
While the 2-ish+ square-inch difference in crossectional area between 2.5 & 3-in pipe is significant (7.07 vs 4.91 ~ rounded), the exhaust-gas stream cools significantly from the turbo exit to the differential......causing a corresponding reduction in volume and tube-size requirement. Soooooo..........reducing pipe diameter to 2.5-inch just ahead of the diff (after the muffler) might not have any negative power impact. BUT.......I wuz wrong once before!  .[Image: confused0024.gif]
As an example of the incremental heat reduction through the exh system, John Sheffler (svojohn) made a 40lb-reduction in his car's weight by replacing all the exhaust tubing behind his stainless downpipe with (gasp) aluminum tubing!  (LINK)..IIRC, that weight reduction also included omitting the muffler. .[Image: happy0034.gif]
You'll just have to get creative.
I just installed a old, modded Steeda 5-Link set-up on my Tbird. I made new upper links, new RUCA chassis mounts, modded the panhard chassis bracket, etc.
I was going to keep the single 3", no matter what. I cut my old Stinger tailpipe into about 5-6 pieces to get it all to fit.
[Image: exhrebuild_13.jpg]
I have as little as 3/8" of clearance as that pipe snakes it's way through all of that.
I locked it down tight with none of those stupid swinging hangers.
[Image: exhrebuild_10.jpg]
I have yet to have any exhaust rattles or contact with any of the other components.
(05-29-2020, 12:22 AM)Chuck W Wrote:  You'll just have to get creative.
He addresses this @ 5:00 dual 3 inch over the MM panhard bar.
https://www.youtube.com/watch?v=yElVnT165sQ
