MSD and factory tach??
Does our factory tach work with a MSD ignition or do I have to have the tach adapter, pn 8910? Thanks guys,
Jay
1985 2R SVO
1985 2A SVO
1994 Lightning
What are you working on?
Sorry foregot that, ts a 85 SVO. From my searching I have come to the conclusion sometimes yes and sometimes no. Ill have to get it hooked up this afternoon and find out.
1985 2R SVO
1985 2A SVO
1994 Lightning
I tried my 6AL the other day for kicks and tachy no worky... [ i need the adapter].
Others here say they are able to run MSD w/o the adapter [i think karnage was one].
I do Ported heads, intakes and rotated ported intakes, PM me for info.
84 Cougar XR7 Turbo
85.5 SVO 1E
86 SVO 1E
I needed the adaptor to make the tach and ebc work on my XR4Ti.
Mine worked with no problems.In fact both my factory tach and monster tach work fine.I have the monster tach hooked right to the MSD port and the stock tach is still connected to the coil.
84TC-gutted intakes-80mm maf-944 FMIC Greddy BOV 72lb inj
PPbig valve head-255LPH kirban-20psi-17"cntlines-65mmTB full 3" exhaust-on the way to 400hp
My 80 Capri needs the adaptor.
11.42@120 no wideband.
Well my 85 SVO needs the adaptor. Guess I will be making a call to find one tomorrow. Thanks guys.
1985 2R SVO
1985 2A SVO
1994 Lightning
Is there a way we could wire the stock tach, to the MSD port??
84 Cougar XR7 Turbo
85.5 SVO 1E
86 SVO 1E
I dont see why it wouldnt work if it is hooked to the coil.Mine works with no problems.
