08-27-2009, 01:20 AM
A buddy of mine had a beat up 87 T top car at his house with an SVO engine in it. He didn't have time to work on it. I was looking for something I could build up to perform well and go to track days with on a reasonable budget. As I tend to...I got a bit carried away.
A week ago the car was basically stock aside from the swap. Since then we've done the following:
tubular k member and front control arms
manual steering conversion rack w/quick ratio
tie rod adaptors with adjustable outer tie rod ends
SN95 front spindles
Cobra R Brembo 13" front brake system
FMIC mounted
All fenders rolled
Front fenders cut for clearance
18X9 Saleen wheels on the front
18X10 Rotas from my Subaru on the back
Toyo R888 road race tires. 265 front 295 rear.
poly transmission mount
new battery
manual brake conversion
Sparco wheel with quick release
6 point cage welded in (so far...we're adding a rear X soon and then more later)
5 point cam lock harnesses and Corbeau seats
Pro 5.0 shifter
Centerforce dual friction clutch
MM torque arm, panhard bar, swaybars, links bushings
full length weld in subframe connectors w/gussets
fuel cell
bosch pump, aeromotive filters
Removed the whole stock fuel system
Lincoln mk7 8.8 rear end assembly
We drilled out the rear hubs and put ARP extended studs in. The front ARP studs went right in.
Cobra rear brakes
MM coilover conversion, rear control arms
wideband, EGT, boost, fuel level gauges installed
Megasquirt 2 built and EEC board built
removed bumper beams, a/c related parts, water cooled oil filter housing and intake manifold coolant hoses, some of the sound deadening, head liner and carpeting.
wilwood brake proportioning valve.
stinger exhaust manifold
HX35
ranger alternator conversion
to install:
40bob intake, TB, fuel rail setup
pyropete EDIS conversion parts
140lb injectors
CDI box, 4 blaster ss coils, and custom MSD wires we'll make to length
Tial BOV
hydraulic e-brake (for drifting/horsing around)
-8 fuel feel line, -6 return, Aeromotive FPR
cobra master cylinder
custom oil cooler
radiator/fans (maybe..it has a truck rad. in it now)
oil pressure and temp. gauges
to fabricate:
intercooler piping and intake
and we need to mod the exhaust the car came with a bit
rear firewall since I have a fuel cell
finish blow down fuel cell vent tube (we stuck a nitrous blow down tube on it, but it's not quite long enough)
Things I need:
solid or much stiffer engine mounts
I'm sure I'm forgetting a bunch because this has all happened rather fast. Hopefully it won't be more than a couple weeks before we fire it up.
We leakdown tested it and unfortunately the engine is pretty hammered so I won't push the tune too hard this season and we'll take care of the engine over winter.
I'm planning to put a coat of primer on it before driving it and deal with the paint and body issues over winter.
The injectors and fuel system are beefed up so much because after I get it running on gas I'm planning to switch it to a special fuel I've had blended which requires more fuel volume to air than E85.
We'll corner balance and align it once it's all together and then it's getting fired up and put straight on our dyno for tuning. I'm putting it on the road so I can shake it down a bit before going to the track. Who am I kidding...I'm going to take it on on the street sometimes...just not on these tires as I won't make it far.
Some in progress pics:
http://innovativetuningdl.com/images/stang/DSC_3031.jpg
http://innovativetuningdl.com/images/stang/DSC_3037.jpg
http://innovativetuningdl.com/images/stang/DSC_3045.jpg
http://innovativetuningdl.com/images/stang/DSC_3050.jpg
I'll take some better pics when I can.
Thanks to nikuk and zer0daze for their guidance since we haven't modded an SVO setup before.
SN95 front spindles
FMIC mounted
All fenders rolled
new battery
Pro 5.0 shifter
fuel cell
Cobra rear brakes
HX35
to install:
140lb injectors
Tial BOV
custom oil cooler
to fabricate:
Things I need:
