Need help locating a pair of Headlamp/Headlight
Hello.  Happy Holiday. Hope all is going well or relatively well with everyone.
I need help locating a pair of headlamp/Headlight, to replace one of the cracked ones. This is the information on the the glass/plastic :  RSD 22V12H  HB5  FR-5025-A  DOT  SAE-HR-01
I did all the search I could and keep coming up empty.
It is in the 87 XR4TI. I bought the car with this conversion done, so no idea what car etc. the person that did the conversion took it from.
 Cheers
88XR4TI:T67/T4 Turbo,85lb inj,PIMPV1.3,LS2-Coils,255LPH,3" exh, Stg4 Head, BoPort Header, Bob's Inline, Cus.body kit, 16" Rims, Supra 3.73 LSD, Rasp.PI3 dash
(05-31-2021, 12:46 PM)jahlive12 Wrote:  I need help locating a pair of (XR4Ti) headlamps/headlights, to replace one of the cracked ones.
Do any of the used ones listed on eBay look like a match?  LINK  (scroll thru choices).  <shrug>
Is this the glass lens light? I see it says Glass/Plastic, please clarify, or put a photo.
Thanks Ray, it is not the stock XR4TI light.  So those are a no go.
I think it is plastic .
See the attached pic of what it looks like.
All appreciate the help
Attached Files Thumbnail(s)
(06-02-2021, 10:36 PM)jahlive12 Wrote:  ......it is not the stock XR4TI light.
LOL ~ I hate to be Debbie Downer, BUT.......I think the chances of finding another light that matches the one you depicted are slim and none, AND....."Slim" left town!! If it's just a crack and you're worried about the intrusion of moisture/water, I suggest Super Glue and just dealing with the cosmetic result. If there's a chunk missing......I'd guess that you're S.O.L. (sorry, outta luck)!! Perhaps post the pic and your need on a Merkur/Sierra site??  <shrug>  GOOD LUCK!
EDIT:  HERE ya' go!
Hey Ray
No Debbie Downer, just reality. When I kept searching and could not find anything, that is what my thought was, Just did not say it out loud Smile . Custom stuff is great until you need replacement Sad . For now I am not going to worry too much about it. The car does not drive at night cannot recall the last time I used the headlights. But will keep my eye out for replacements or getting in line for special order from Poland
They look like aftermarket projector housings for an '87-93 Mustang...
'72 Pinto Runabout-2.3T/T5/MS-II.
I'll show those guys who's in top place, I'll really give'em a hotrod race.
(06-10-2021, 12:49 AM)65ShelbyClone Wrote:  They look like aftermarket projector housings for an '87-93 Mustang...
I believe you're correct.
I believe you are correct, I found a cheap set on e...y. with all the connectors etc. I will advise how they stack up once they get here.
Thanks 65ShelbyClone and others for helping with the search.
#10
They worked, no cracks now
