Need part number -- nylon Fuel line from tank to steel lines
Do those of you who use high psi fuel injection rubber hose deal with any fuel vapor odors? Especially if the car is parked in garage? I was going to use -4 aero quip push on hose since they fit the dorman ends up until I heard many a complaint about the ethanol mixed fuel odor coming right through the hose wall. I will probably order some nylon parts from fuelsender.com.
Restoring '84 Mustang GT Turbo 2E, SPDIS, air dam, lowered, basic bolt ons, super 60, PK1, 35#ers, RR +4*
Quote:Originally posted by NigelM:
Quote:Originally posted by shorangerbird:
[b]
[b]
Ford never stocked complete fuel hose assemblies - only ends, couplers and bulk hose.
-not true. [/b]
I'm talking about SVOs here. [/b]
I have a brand new Ford fuel line assembly from tank to engine. They did sell them.
85.5 SVO 3" downpipe with 2.5" welded
Ultraflows, 255lph pump, adj. boost control, soon to be fm intercooled
[b]
[b] </font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by NigelM:
<strong>
-not true. [/b]
I have a brand new Ford fuel line assembly from tank to engine. They did sell them. </strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">-exactly...part number i gave is the SERVICE Replacement for mustangs & SVOs for '85/86 vintage...its E3ZZ-9J279-B for SVOs built before 11/84.....
too many projects.........
'87 turbo coupe w/only 538 actual miles...
Is this information still accurate? I am fabricating any hoses I need from the hard lines to the fuel rail? I somehow managed to source the soft hoses from the hard lines to the tank a couple of years ago but I'll be damned if I remember where.
Wellll.......it probably doesn't matter whether those part numbers are accurate or not, Andy ~ since it's extremely unlikely that ANY of 'em are still available. The only source that I can POSSIBLY imagine for those parts would be some kinda NOS supplier that has 'em squirreled away for huge profits.
Instead, I suggest making new lines from scratch, using Nylon tubing and components like those depicted on THIS page. OTOH, if you're building some kinda whatup gee-whiz race car that requires larger lines, you might also consider stainless hard line and AN fittings.  <shrug>
#16
You'll have to verify hose size but I got the SS braided lines from an SN95 to go from the tank fittings to the chassis lines.
83 & 84 GT turbo, 84, 85.5 & 86 SVOs
87 & 88 TurboCoupe
93 5.0 notch, 95 GT coupe & vert, 96 GT vert  (Yes, I have a probem, garage's too small!)
#17
(09-05-2021, 01:06 AM)TurboRay Wrote:  .
Not building anything insane, but I did put in a Walboro pump, new sending unit/filter, pressure regulator and  stainless hardlines. The last because whoever welded in the subframe rails under this car positioned the factory lines directly under a jacking point, which did not end well for the factory lines. I figured whats 20 bucks more for stainless and a little piece of mind. I can do what I want to the motor and not have to worry about the fuel system. The amount of pressure I have from the pump can easily be handled by factory hoses and that pressure is more than enough for any plans I may have for the motor. My car will be far from a sleeper for any that know what they are looking at but I like to keep things subtle. That nylon hose should help with that. Thanks
(09-11-2021, 07:58 PM)teal95 Wrote:  You'll have to verify hose size but I got the SS  braided lines from an SN95 to go from the tank fittings to the chassis lines.
Good call man. SN95 should have the same fittings assuming the line is the same size.
#18
Keep in mind that - IF you terminate(d) those hard or braid-covered stainless lines/hoses with OEM "Spring-Lock" connectors (in order to couple with the factory fuel rail) - the male ends of those connectors both neck down to 3/16 ID. <eek> This is b/c they have to accommodate the ID of their machined double o-ring grooves.
Most folks don't seem to have a prob forcing a sufficient volume of 40-ish psi fuel past those arguably restrictive bore sizes at "usual" power levels. BUT......I can foresee a possible issue if E85 (or any alky-based fuel) were used with, say, 20 psi or greater boost. Just sayin'.......  <shrug>
