Welcome! I'll be 69 on Thursday and I'm on the left coast too. SF Bay Area. So we have a couple things in common. Your project sounds fun. For the motor, I would suggest at least a seal-n-shine. Drop in new bearings, oil pump and have the cylinders mic'd. With only 86k you may be able to get away with not boring it out and buying new pistons. If so, have it honed and slap in new rings. Contact Bo @
https://www.bo-port.com/ and see what he can do about some basic headwork. Your T3 turbo should be just fine for the job. A mild cam and a header or log manifold with full 3" exhaust will put you easily into the 300hp category. These little 2.3's are stout and I've seen many run well beyond 300K miles before a rebuild was necessary. The Zero kit car looks extremely light and should respond well with a mildly modded 2.3T. I dropped a built 2.3T into my '27 Model T roadster and it's a blast to drive! It too is over 300hp and the car weighs under 1500 lbs, soaking wet. Goes like a bat outta hell! I call it my 300hp go-cart.
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
Thunderstang (DECEASED)
'27 Model 'T' w/2.3T
'54 Ford Customline 5.0/AOD
It definitely looks like we are on the same wavelength, evintho. I like your rig and the level of mods you have done to it. I left a message with bo-port. We'll see what happens. What computer are you running?
I got the engine down to pulling out the pistons. The bores are really clean and have the original honing like it was assembled at the factory yesterday. I'm thinking of a 1.5 level roller cam and have the turbo rebuilt at Evergreen. I'd like to keep the original manifolds, at least initially. My intake is 84 SVO so the alignment of the upper half can't be rotated (the ports are arranged in a row front-to-back) - not in a square like the later 2.3T engines. I'll probably have to fabricate an upper to run a forward-mounted intercooler.
Your engine set-up looks so clean that it is inspiring!
Paul LeDuc likes this post
Thanks! I'm running an LA3 ECU out of an '88 TC. Might I suggest starting a build thread so we can all follow along with your progress?
Proverbs 3:5
(04-04-2025, 01:04 PM)Cobrapatrol Wrote: (04-02-2025, 11:01 PM)evintho Wrote: Thanks! I'm running an LA3 ECU out of an '88 TC. Might I suggest starting a build thread so we can all follow along with your progress?
Yes, I will.
Welcome! IIRC there was a member that did just what you are planning. I'll do my best to see if I can figure out who it was.
(2) 84.5 TurboGT 'verts/84.5 TurboGT hatch/(3) 86 SVOs
86 LX 2.3 (project Ratstang)/04 SVT Focus #1276
77 F-350/40 Ford Sedan/67 Fairlane GT 'vert
In a 4-4-2015 car show here in Jupiter,FL there was a Lotus super 7 kit car with a Ford 2300 T-3 turbo installed. I have 8 photos of the car in a Word document file but do not know how to post them. I can email them if desired.
Paul LeDuc and Jerry J
Yes, I'd be interested in seeing another 2.3T Lotus 7 project.
Cobrapatrol,
I just sent the 8 photos to your email address.
Have fun.
Jerry J
Thanks Jerry, I got your photos. Very interesting to see another example for my project.
