OMG! That stuff stinks!
Holy crap! I put some of Fords friction modifier in my auto trans and wow! What a stench!
Its been 4 days and my whole car inside and out still smells! I dont have a leak so I'm wondering how long this is going to last, anyone know?
Jerry Rutten
88 Turbocoupe
lotsa miles,lotsa work,lotsa money,lotsa boost!
Jerry R.
88 Turbocoupe
Why did you put it in yer automatic? - it's not designed for that! It's made to modify the fritional properies of gear oil for use in limited-slip diffs. On occasions, I've used it in stick-shift trannies to alleviate hard shifting in cold weather - but I've never heard of anyone using it in an automatic. [Image: smile.gif]
From what I understand it helps alieviate some of the heat and sress on the clutches and bands when they make"soft shifting", thus,firmer shifting and less wear.
It does shift better, but smells like s**t!!
Jerry R.
88 Turbocoupe
Hehehe,that stuff is made from fish oil I believe.If you ever want to throw yourslf across a room,take a deep whiff from the bottle.
wrong... it makes them slip more... that's BAD for an auto...
get that shit out of there ASAP!
Forrest
I thought Ford went away from the Whale Sperm friction Modifier. They have a new modifier that does not stink nearly as bad. I think it is synthetic. I have head of guys running the friction modifier in SHO and Conturd 5 speed trannies...
Forrest
Yep, it is made to reduce the clutch chatter in trac-loc rearends. It does this buy reducing the the amount a friction so they slip more.
Might want to get it flushed out.
Later
Randy
87 Mustang coupe 3100# with me in it
Stock bottom end, home ported head, with stock valves, home ported lower, gutted upper, home ported E6, single 3" exhaust, Ranger cam--retarded 4 degrees, 255 intank with #6 lines, Aeroquipe FP regulator, la3, k&n, 87 tc 5-speed with 8.8 and 3.55's, stock 86 TC 5-speed turbo running 20#, starion front mount IC, underdrive pulley, msd Digital 6 - only help with the launch, 6*10.5*15 E.T. streets
Best on motor
1/8th 8.10 @85mph
1/4 12.79 @105.64mph
Best on NX 50-shot
7.70@ 90mph
12.12 @ 113
85 2.3turbo Rx7
10.88@125.6-no nitrous yet Smile
Dead and crushed Sad
82 Toyota Starlet KP61
pushrod 4cyl
10.47@135 on dots
Some old transmision guy told me about using that stuff in auto trans befor. He said if your trans is slipping because of bad seals this stuff will help make the seals soft again and help clean the gunk out of the valve body, He said not to leave it in more than 20 or so miles because it will mess up the discs/bands in the trans.
Dont know if this is true or not, since I have never tried it. Autos are easy enough to rebuild anyways.
My vehicle
1983 Turbo Coupe with a GN intercooler, dawes device set at 22psi of boost,K&N cone,fully ported e-6 manifold,gutted and ported intake, ported stock valve head, Ranger cam set -2 deg, and Full 3" exhaust with 3" magnaflow, 190 pump, a TRI AX shifter,Madhatter clutch quadrant,Racer walsh adjusatble cam pulley large VAM, LA3, brown tops, and 88 TC wheels. Next mods, boxed control arms, Subframe connectors, 3.73 8.8 rear,Larger front brakes, and poly bushings. Then i have no ideaSmile
has run a best of 14.71 at 92mph on drag radials. New times with GN intercooler, LA3, brown tops!!!! 14.9 at 96mph on my street tires.
New times with head ,e6 and ported intake, 100 race fuel, and 28psi 13.83 at 103mph!
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
3tc powered sandrail.
nope.. the stuff promotes slipping.. if you dont put it in a limited slip.. you will have no slip
if you put it in an auto.. you will start to slip under high power aplication( WOT in 2nd or 3rd) and eventualy in all gears
better get it out.. i know first hand.. dead tranys suck
<---GREENTURBO---<<<-
**INJECTIONS NICE.. BUT I'D RATHER BE BLOWN**
**"In life we live and die, somewhere in between we work on cars. We should all be so lucky**
** 65 mercury comet caliente, hi-po 289 **
**68 Galaxie 500 fast back, 390 big block**
They did - the tree-huggers whacked their peepees! But there are probably a few bottles of the orig/smelly stuff out there - lol. [Image: smile.gif]
[This message has been edited by TurboRay (edited 12-03-2001).]
