1 set upper & lower 2.3 Pinto alt brkts. NOS lower is the coveted (rare?) aluminum version. The top bracket (good/used) is steel and fairly heavy (2lbs 2-1/2ozs, vs aluminum lwr @ 1lb 6-1/2ozs).
I also have several NOS aluminum lower brkts by their lonesome (w/o an upper). Because of its' weight, I personally will be using the aluminum lower w/o the factory upper, by tensioning the belt instead with a homemade "rod-end turnbuckle" (L/H & R/H-threaded rod ends separated by an threaded aluminum turnbuckle. A small alum angle bracket will attach one end to the head. But.....whatever blows yer skirt up. :dunno:
1 - Pair of upper and NOS aluminum lower brkts (only pair available) = $100 + actual shipping, via USPS Priority Mail.
1 - Lower NOS aluminum bracket (several available) = $60 + actual Priority-Mail shipping.
![[Image: dIHTOoY.jpg?1]](https://i.imgur.com/dIHTOoY.jpg?1)
![[Image: zvIMaHu.jpg?1]](https://i.imgur.com/zvIMaHu.jpg?1)
