Premium Fuel switch
In wiring my sandrail I wanted to by pass prem. switch. Would running prem. wire from eec to the signal return wire be the correct way?
Well...There are two parts to the Premium Switch logic. One part (the part you refer to above) controls the timing map, and the other enables the BCS. You are right about the timing side.
If it were my buggy, I'd wire in the switch. Sometimes I find less power useful.
Jim Simmons
1980 2.3 Turbo Courier Pickup Truck
Modesto, California, USA
Take what you like and leave the rest.
Get American Flags here under Coolstuff.
Courier SVO donated to msm
'63 Ranchero, 260, EFI, AOD
