Refinished OEM oil pan with welded oil return See pics $60
I have a nice OEM ford pan with the grooved crank/rear main mating surface that I stripped down to bare metal, welded a 10an oil return fitting and painted the pan ford gray.  Has a couple of minor dings see pics (got it that way), it is true and straight otherwise and will mount up perfect.  Also has a splash/baffle on the inside.
60$ shipped.  I have way too much time invested in it but my loss is your gain.
Located in Los Angeles.
Im going to be listing more performance (pimp, injectors, etc) and oem parts (intakes, valve covers) in the coming weeks as I clear out my garage.
You can also email at 23reasons attt gmail dot com
https://imgur.com/ENnRbHs
https://imgur.com/UaRa3ny
https://imgur.com/BWrZXE8
https://imgur.com/A6GdCMV
many Fords, just no time...
