Screaming Turbo
Stock 86 SVO 2.3T
Pretty sure my turbo is in need of replacement.
Loud screaming/squealing noise that is directly proportional to boost level, but its hard to tell.
Also getting a bit of smoke out of the exhaust after driving and coming to an idle. Not usually at startup.
Pulled inlet off and there seems to be a decent amount of side to side play in the bearing w/ some of what appears to be damage/roughness to the fins themselves. Doesn't seem to be making contact with the housing though. Plus some oil in the compressor side and intake before the inlet.
Would that be responsible for the noise and/or smoke?
https://youtube.com/shorts/M-pq8gprf4o
