spark plug gaps
this may seem like a rather simplistic question,but what spark plug gap is recommended for these motors,have a miss fire at 3000 to 4000 rpm and 15psi boost,is this my problem? thank you t.trepanier
DADDY DOG
I like .032 on my drivers and .035 on my projects that get taken care of a little better.
Dont run platnuim plugs! Get the cheapy motorcraft asfw32's .
A miss is usually the wires which seem to crap out on these cars pretty fast. Stck to the motorcraft plugs wires and cap/rotor and you will be happy you did.
If the miss does not go away, do a code scan.
Newbie with dumb newbie questions...
some wiring diagrams and by some , I mean none at all.
1984 GT350 T-top New pics
1984 Turbo GT T-top 419rwhp
On my car I had to drop the gap down to .025 but I am running pretty high boost 20-24psi. I would start by closing the gap down to .025 and increasing it in stages until the car runs bad again then close it up to where it ran good.
Good luck
Shawn
My vehicle
1983 Turbo Coupe with a GN intercooler, dawes device set at 22psi of boost,K&N cone,fully ported e-6 manifold,gutted and ported intake, ported stock valve head, Ranger cam set -2 deg, and Full 3" exhaust with 3" magnaflow, 190 pump, a TRI AX shifter,Madhatter clutch quadrant,Racer walsh adjusatble cam pulley large VAM, LA3, brown tops, and 88 TC wheels. Next mods, boxed control arms, Subframe connectors, 3.73 8.8 rear,Larger front brakes, and poly bushings. Then i have no ideaSmile
has run a best of 14.71 at 92mph on drag radials. New times with GN intercooler, LA3, brown tops!!!! 14.9 at 96mph on my street tires.
New times with head ,e6 and ported intake, 100 race fuel, and 28psi 13.83 at 103mph!
273RWHP and 342FTlbs at 24psi
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
3tc powered sandrail.
Quote:Dont run platnuim plugs! Get the cheapy motorcraft asfw32's .
[/B]
This is true I put platinums on my engine and it right away caused a miss and I think the burned too hot too because my head gasket eventually burned up as well between cyls. I replaced the head gasket and put stock Motocraft plugs/ wires/ acap and rotor. It runs better than when I bought it.
1988 TC...5spd of course!!!!
1992 Mustang - 2.3 turbo - sold
1991 Notch - 5.0 turbo - sold
1999 Chevy Z71 4x4 - 6.0 turbo
1993 Civic hatch D16 E85 turbo
You mean AWSF32C don't you......
or one step colder: AWSF22C Motorcraft,, Autolite #103.
hope this helps...
A note about platinum plugs. For use in any vehicle, the plugs have a lower internal resistance than the standard plug. If they are gapped at recommemded specs, they may cause a misfire, or weak fire as there is not enough resistance to get the voltage up for a hot spark, ie., the spark can easily jump the narrow gap with not enough energy to properly ignite the fuel mixture.
The trick is to widen the plug gap increasing the resistance the ignition circuit "sees", and the circuit will raise the voltage to jump the gap giving the hotter spark.
If it ain't old, it ain't s***!!!!
Another vote for AWSF32C plugs at .030.
If you have a higher RPM miss, look to the plug wires, cap and rotor also. Some brands of wires many consider to be "good" quality wires dont work well on 2.3Ts. Bosch wires come to mind... no one, including me, has had decent luck with these wires. You cant go wrong with the Motorcraft wires (#WR4011C), and Motorcraft cap and rotor. Run codes, and look for a continuous memory code 14: intermittant PIP. This could be caused by a bad PIP generator, or more likely, from EMI from the plug wires, cap or rotor.
Jeff Korn
86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP NOS, ignition, gears, suspension, etc., etc. // 88 Turbo coupe, Intake & exhaust mods, Garrett T3 turbo, 20 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, etc., etc. // 91 Escort winter, work car // 00 Windstar (wifes vehicle)
Jeff Korn
86 Tbird 5.0 - lots of mods / 88 Turbo Coupe - lots of mods / 05 Taurus Duratec / 04 Taurus Duratec (wifes) / 02 Grand Prix GT
See my post above concerning platinum plugs.
[This message has been edited by joebltzfk (edited 12-09-2001).]
I tried platinum plugs in my car, I couldnt get them to run correctly at all. Whaen I first got them i tries a .030 gap which caused a mis so I did like you said and the plug manufacturer recommended and gapped them to .040 still no change tried them all the way to .050 and then the engine wouldnt go past 4500 rpm it just fell flat on its face. I gapped the stupid plugs back to .030 because that is were they ran the best and I was going on a road trip. on the trip going up hills the car would mis bad and felt like it was running out of fuel, It wasnt it was the crappy spark plugs, I had to gap them down to .020 just so I could get up the freaking mountain! The first town I came to after getting up the mountain I stoped at the Checker and bought a set of autolites put them in and didnt have any problems the rest of the trip.
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
[This message has been edited by sctur601 (edited 12-09-2001).]
2000 jeep GC
1979 mustang notch
84 ranger 351w
1998 contour svt
