Thread Closed
SS BIG VALVE GROUP PURCHASE ( DISCUSSION ONLY )
<font size="+3"><center><B><font color="#043db2">
<marquee scrolldelay="1">STAINLESS STEEL BIG VALVE GROUP PURCHASE</marquee>
<font size="+1">
ORDER WILL BE PLACED AS SOON AS I HAVE 10 ORDERS.
The specialty OVERSIZE valves are one piece forged, pure 21-4N Stainless Steel, 1.89" intake, 1.59" exhaust. Machine work is required to get these BIG valves in there, of course. These are fully polished, undercut for maximum airflow, and feature a 50Rc embedded wafer tippet. 4.80" OAL, 11/32nds stem, .550" tippet length.
ALSO AVAILABLE:
DUAL SPRINGS
spring specs are.
dual, test spec is 115# @ 1.650", 220# @ 1.150", coil bind
is .950". OD is 1.385", ID is .810"
Finewire spec, Australian made.
*NOTE some models require machine work to the spring pad ID to clear the reverse wound inner spring.the one piece retainer is Chrome moly.
We can also add,
A set of Manganese bronze valve guides, .502" OD X 11/32nds ID
YOU WILL ALSO RECEVE A SET OF TEFLON VALVE STEM SEALS WITH THE PURCAHSE OF THE VALVE GUIDES
Please PM JUSCUZ for pricing.
If you can smile when things go wrong, you have someone in mind to blame.
I understand that machine work is required to the seats to make these fit, but the remaining dimensions(length and stem diameter) are factory on an 88 T-coupe, right?
Thanks,
Michael
1996 Ford Mustang
2.5t Folvo w/ HE351VE, MS3X, & TKO500
1958 Plymouth Savoy
Flathead 6 and 3-on-the-tree
2018 Audi RS3
2.5t, AWD
11.23 @ 121 mph
CORRECT!
I am interested in a complete set of valves & springs & guides. What is the total with shipping to 34610 and what is the ordering status at this time. Thanks Len.
87 TC 5spd., T-3 , Engle Hyd. Roller , Bob's int. , Ported E6 ,ported head,gillis , bosch BOV , cooler fan, 3" down/2 1/2 duals , 255 & kirban.Spec 3
PM SENT
I am interested in all three valves,springs,guides. but i would like to know how much. if you could send me a pm
thanks
mike
86 GT T-Top 08 hemi ram
2011 Gt/Cs 647 hp jpc tuned
90 2.3 turbo hatch 99 csvt contour
count me in on this group purchase
OK lets get some people to commit here....I will order if I get 5 orders...
pm sent Big Grin
80 PINTO turbo (sold) 88 tc needs work
HOW MUCH FOR ALL?
86 XR- FMIC,GILLS @20,PORTED E6,3" EL-BO,FULL 3" NO CAT. P.E.EEC,BIG VAM,
Thread Closed
