01-15-2020, 05:53 PM
(This post was last modified: 01-15-2020, 05:59 PM by
Howard.)
I have a REALLY cherry 1986 SVO steering wheel, but I wish to install cruise control. I would rather install a different wheel than modify the original. Can anyone list the years of Ford OEM steering wheels that work with the 1986 column?
1986 SVO daily driver. PiMP v1.4/3" Stinger exhaust/FMIC/Schlodes Manifolds/Boport 2.1 and head/GM 3700 stall 200-4R auto trans
01-15-2020, 09:52 PM
(This post was last modified: 01-15-2020, 09:55 PM by
Howard.)
(01-15-2020, 09:36 PM)FLHotRod Wrote: (01-15-2020, 05:53 PM)Howard Wrote: I have a REALLY cherry 1986 SVO steering wheel, but I wish to install cruise control. I would rather install a different wheel than modify the original. Can anyone list the years of Ford OEM steering wheels that work with the 1986 column?
Depending on the cruise control, you can try the Rostra 250-3032. Just cut your turn signal lever to whatever length and no need for a different steering. I have a Rostra Universal System on my SVO (have not had it work yet - just found a wiring issue from original install). Once I finish other work, I hope to get this working. Rostra Cruise Control Switches
Regards,
Harry
Thanks, Harry, but I am looking to use a Ford wheel that has the buttons integral to it! I will be using the cruise system off my '84 Turbo Coupe parts car. THAT steering wheel is shot!
