09-21-2005, 10:07 PM
Chassis type:
short block mods/compression ratio/displacement:
head/port work/valve size:
cam specs/degrees adv-ret:
intake/throttle body:
intercooler:
nitrous system/shot size:
exhaust manifold:
turbo:
wastegate:
exhaust size:
engine management:
a/f ratio, total timing, boost:
fuel octane/brand/leaded or unleaded:
hp@rpm:
trq@rpm:
flex plate/flywheel:
convertor/clutch:
transmission:
rear/ratio/tire type/tire size:
race weight without driver:
ET/MPH:
next areas to be improved:
intercooler:
exhaust manifold:
turbo:
wastegate:
exhaust size:
engine management:
hp@rpm:
trq@rpm:
convertor/clutch:
transmission:
ET/MPH:
Living isnt to arrive at the grave safely in a well preserved body, but rather skid in sideways, totally worn out, shouting 'holy sh**, what a ride!'
