SVO question
One of my customers just bought a 84 SVO, and being the SVO idiot that I am I have some wheel fitment questions
What wheels can and can't he run(I knwo there is hub interference on the 98 Cobra, 99 Cobra and the 2001 Bullits)
Laters..
Mark
94 and 96 cobra rims are ok to run
95 cobra and cobra "R" will not work
Rescue Turtles, they need our help!!!
Early 85 SVO Comp. Prep.
88 Notchback-- 2.3t
92 SAAB 9000CD-2.3T
63 Buick Skylark
http://www.angelfire.com/wa3/fastest4d/
94,95,96,97 cobra rims are all the same
As for the Rs why don't they work, too wide?
Laters..
Mark
The SVO has the older style hub that has a larger diameter and protrusion than the newer 5 lug hubs. Thats why.
You could upgrade to SN95 spindles & rotors & do it that way or have the rims machined to clear the rotor hub. I have seen an SVO running the bullit wheels. Check out this link: http://www.svpu.com/svo.html
They had to do mods.
-mike
69 Mach1 (Garage Queen)
81 Stang 2.3na T5, koni's, cc plates, gt sways, dual exhst
86 SVO 9L f/r strut braces, big alum radiator, TC fans, stock motor
89 F250 4x4 460/C6 Gear Vendor OD, lift, 35's, Borla Muff, K&N Cone
90 5.0 full global west suspension, M2300K discs, BBK x-pipe, cat-back, stock internals
-mike (aka AT6svo)
69 MachI, 83 GT Turbo 9L, 84 SVO 9W, 86 SVO 2A, 90 LX 5.0 all for the twisties....
Im running cobra R 17x9 on my 84 SVO with 255x40 tires. I suggest you run the car at its stock height.
84 SVO V1 trim turbo, SDS fuel system,MSD Ing,Custom Head,Custom Int-cooler,9"Rear pushing 350 Hp.
I'm running 17 inch 95 cobra wheels. They really change the look of the car and let the brakes run alot cooler. There is no question that these wheels will work on your car, but I do have rear wheel scrape over bad bumps and if I back up and turn the wheels sharply the front tires scrape. It is only a slight problem, but I think it is worth it to have the look. My car is not lower, but if it were, I think that I would have more of a problem.
Ralph
