So I have a 1990 Ranger im doing a 2.3t swap in. I recently got the motor, harness( what I believe is the full harness) and ecu out of a 87 thunderbird. I realize the 87 harness is a nightmare I’m just wondering what connectors I need and what connectors I do not need. I do not have the extra money for the standalone hence why I’m going to use the factory harness. I just need some assistance on what wires to use and what wires I can get rid of. Thanks!
This will be a HUGE help and the best $30 you ever spent on the project...……….
https://www.ebay.com/itm/1987-Ford-Thund...Sw1vlUrxBq
Trust in the Lord with all your heart and lean not on your own understanding.
Proverbs 3:5
Thunderstang (DECEASED)
'27 Model 'T' w/2.3T
'54 Ford Customline 5.0/AOD
VAM connector and coil connector should be all you need. Maybe TPS depending on which throttle body/TPS you use. This is assuming you're using an 87-88 TC ECU and a distributor rather than the Ranger dual plug ignition. Our 91-93 turbo swap page is about 99% the same as the Ranger swap.
