you don't necessarily have to have the exactly correct spring on your wastegate, it just needs to be lower than or equal to what boost you want to run.
if you want to run higher boost than the spring is rated for, you just need to also run a manual boost controller.
also, the reason the spring seems awfully stiff, is because 20psi is a **** ton of boost
Lets see, if you have 8 to 1 CR and you have 18lbs of boost, it's like having a 17.8 CR and you want to run 26lbs of boost, good chance you'll do more than just blow a head gasket. Maybe not you can see why they don't recommend going above 20 lbs of boost.
Rob Hilton So Ca
Save time E-Mail Me at:
[email protected]
^^ Maybe I'm misunderstanding you, but are you saying that they don't recommend going over 20psi with this gate? Im at 26psi now on an internal gate and haven't had any problems with headgaskets(current HG is 3+ yrs old)...so Im not sure where you get that anything above 20psi will eat a HG. :confused:
Ok, so compression ratio figures into the equation then? The WG came with about 7 springs...
88 TC 2.5 5spd~money pit
put in a spring rated for less psi than what you want the turbo to run at. use a manual boost controller and boost gauge to get correct boost. not really anything else to it.
The Tial website has a diagram How to hook up the manual boost control valve. I prefer the 7 lb spring myself. I'm running the tial 38mm and with the bleed off valve I am able to control steady 26 psi. That's with torco mixed to 100 octane and 26 deg. advance. Of course Your results will depend on Your combo, and tune
89 Notch: 85 1/2 SVO
