Valve springs List
Since there is a need for springs that work. Decided to start a list
Anyone can add there working combo.
Crane 99838-16 install at 1.55" with 99936-8 retainers. Note. Seats and guides need cut for larger diameter springs. Use .530 viton seals. Can use +.050 or minus -.050 keepers for proper installed height. Good for .540" lift. 151# at 1.55"
Use Crane catologue for complete specs.
89 Notch: 85 1/2 SVO
Here are some threads that should be helpful for reference:
http://forum.turboford.org/ubb/ultimateb...298#000015
http://forum.turboford.org/ubb/ultimateb...282#000003
http://forum.turboford.org/ubb/ultimateb...878#000008
http://forum.turboford.org/ubb/ultimateb...895#000001
I will be installing some 990s in my 2R SVO over the winter. I need to replace the valve seals so I'm going to put the springs in too. It has a Crane 194621 (A-234 cam) in it now.
(2) 84.5 TurboGT 'verts/84.5 TurboGT hatch/(3) 86 SVOs
86 LX 2.3 (project Ratstang)/04 SVT Focus #1276
77 F-350/40 Ford Sedan/67 Fairlane GT 'vert
